Activity › Forums › Apple Final Cut Pro Legacy › Multiclip editing is choking during playback
Jeremy Garchow replied 18 years, 10 months ago 4 Members · 13 Replies
David Roth weiss
October 20, 2007 at 8:34 pmYour throughput is pretty good, but probably not enough for six streams of 720p Pro Res.
Now, what your gonna probably need to do is drop one stream at a time from your multiclip to see how many streams you can handle at one time before choking.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Les Kaye
October 21, 2007 at 2:36 amI haven’t worked with ProRes, and I’m not in front of a work system, but…
-try going into User Prefs and setting “Limit Real Time Video” to 100mb/s
-Start changing the settings on the Sequence RT button. Try Unlimited RT, Dynamic, and Use Playback Settings.
See what the above helps.
Good luck
Jeremy Garchow
October 22, 2007 at 8:21 pmIn my limited/short experience, ProRes is really really good at scaling for rt. Better and so completely different than anything FCP has ever done for us before. As long as your rt is set to dynamic in both frame rate and quality, you should be golden. I just tried an 8 clip multiclip with ProRes 720p24 and it’s playing back nicely in dynamic rt. My drive is running faster than 300MB sec, but that should be enough throughput for you, especially with dynamic rt.
Jeremy
