Activity › Forums › Apple Final Cut Pro Legacy › multiclip done, now I need to fix a dead pixel, question regarding maintaining multicut edits
  • multiclip done, now I need to fix a dead pixel, question regarding maintaining multicut edits
    Posted by Todd Reid on August 4, 2010 at 3:01 pm
    I know how to fix the dead pixel, that is not my question.
    editing a concert…
    I put all the 4 cameras on different layers, since there was not continuous footage on any of them,
    I syncd them all up, then exported prores versions of each layer, which I took and created a multiclip from these exported files.
    We found that one camera has a dead pixel and we want to fix it with a third party software.
    Can I fix it on the exported clip, and then maintain all my cuts (1 hour & 1/2 show)?
    Any suggestions or confirmations would be greatly appreciated.
    thanks
    Jerry Hofmann replied 16 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 4, 2010 at 4:45 pm
    Seems to me you can if you collapse the multiclip, then take the original stream of that camera offline by just putting it in another folder. Then after you fix the pixel problem, import that single file back in and reconnect the sequence to it.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
