Activity Forums Apple Final Cut Pro Legacy MultiClip Audio Track
  • MultiClip Audio Track
    Posted by Allan Martin on July 4, 2010 at 8:27 pm
    Hello Everyone
    I’ve setup a multiclip using 3 cameras, all of which have an audio track. The audio has defaulted to use the first camera, however I need it to ONLY use the audio from the 2nd camera, but cannot see how to do this. I’d like it so that when I edit with this clip, the 2nd audio track is used and every time I switch between cameras it continues to use the audio from camera 2? Any help would be great.
    Thanks and sorry,
    Al
    Jerry Hofmann replied 16 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 6, 2010 at 1:08 pm
    Put your multiclip in a sequence, and set the opening shot to be Cam 2. Then in the oval button in the Canvas above the video set it to be editing video only.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
