Activity › Forums › Adobe Premiere Pro › Multicam Sequence audio sync problem
  • Multicam Sequence audio sync problem
    Posted by Paul Boone on November 6, 2015 at 5:22 pm
    Hello,
    I’m editing a wedding using multiple cameras that are sync’d into a multicam clip. When I’m viewing the program monitor with the sequence selected, everything is perfectly sync’d, but if I double click on the multicam sequence to edit in the source window, the audio is totally off and not even close. From the source window, I can also go to the Audio Track Mixer tab, and the sound is instantly lined up and perfect. I click right back on the source window and its totally off.
    Is it just too intense for my computer and is glitching or does anyone have any idea what’s going on?
    Thank You!
    Paul Boone replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
