Activity Forums Adobe Premiere Pro Multicam questions on Premiere CC
  • Multicam questions on Premiere CC
    Posted by Chi-ho Lee on January 16, 2014 at 6:55 pm
    I’m working in my first Premiere Pro CC project in a multicam environment. I came from a FCP 7 background. Have a few questions:
    Can I toggle the multicam angle views between 4, 9, 16 cameras? If I have 9, can I just look at 4? Or is it controlled by PP?
    How do I can a new camera to an existing multicam clip?
    I am not able to create multicam with an 8 channel audio only file being one of the angle. I’m attempting to sync with In points. PP will create a multicam clip but it just leaves out the audio file. Any idea why?
    Thanks for your time and help!
    Chi-Ho Lee
    Film & Television Editor
    http://www.chiholee.com
    Chi-ho Lee replied 12 years, 8 months ago 3 Members · 4 Replies
  • Alex Udell
    January 17, 2014 at 3:28 pm
    hi…
    I don’t know about switching between the numbers of cameras you’re viewing…
    but as to the second question…
    fundamentally, a multi-cam source is just a nested sequence…
    so if you need to add another camera,,,
    open the existing sequence and add it as another layer in the stack…
    ta da! 🙂
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Robert D’alexis
    January 17, 2014 at 6:32 pm
    [Chi-Ho Lee] “Can I toggle the multicam angle views between 4, 9, 16 cameras? If I have 9, can I just look at 4?”
    Yes you can. Go to “Settings” (the wrench icon) in the Program monitor > Edit cameras >
    uncheck the camera(s) you don’t want to work with.
  • Chi-ho Lee
    January 17, 2014 at 6:42 pm
    [Robert d'Alexis] “Yes you can. Go to “Settings” (the wrench icon) in the Program monitor > Edit cameras >
    Thanks but not exactly what I was looking for. But I appreciate the reply. And also thanks to the others.
    Chi-Ho Lee
  • Chi-ho Lee
    January 17, 2014 at 6:43 pm
    [Alex Udell] “so if you need to add another camera,,,
    Ok, but that means you have to sync it manually yourself? Can you add a camera after the initial creation and still use sync with marker or audio?
    Chi-Ho Lee
