Activity › Forums › Apple Final Cut Pro Legacy › Multicam Editing with Offline J-PEG
  • Multicam Editing with Offline J-PEG
    Posted by Abs Visuals on November 1, 2005 at 1:58 pm
    Heres one for you geniuses
    I have been attempting to edit in multicam mode at Offline JPEG resolution. Everything goes to plan right up to the point where one begins to cut between the shots. When the viewer and the timeline are ganged open, and the timeline is played camera angles in the viewer do not play as they should, ie they play as if almost needing rendered ehich obviously is not possible. When I select a shot to cut to the blue marker does not appear on the timeline, in fact the timeline stops and so does the viewer, I hope this reads better that it sounds.
    I would really appreciate any possible guidance on this one.
    Thanks from sunny Northern Ireland (for a change)
    Mark Raudonis replied 20 years, 11 months ago 2 Members · 1 Reply
  • Mark Raudonis
    November 1, 2005 at 3:25 pm
    Have you upgraded to 5.03 yet?
    I know that this latest version of FCP addresses some peculiarities of multicam operation.
    mark
