Activity Forums Adobe Premiere Pro Multicam Editing Problem
  • Multicam Editing Problem
    Posted by Ryan Sarver on June 18, 2013 at 10:19 pm
    Alright, I have a problem I need some help with. So basically I am working on a video that has multiple interviews all taken with two cameras. I have synced each interview up separately so each interview is its own multi cam sequence.
    How I have been working is that I first cut the content that I want from each interview and then lay them all down on a new sequence to cut back and forth between the footage. It isn’t until I have all the content I want locked that I go back and do my camera switches.
    Here is my problem. When I open the multicam monitor I see the cuts….press play and start switching. However, when I jump to the next multicam clip in the timeline instead of the monitor switching to the different clips it keeps playing the original multicam clip I started cutting on and it writes over the next clip .
    This video will explain it much better than I could type.
    https://youtu.be/hLxZZcv-nFs
    Please help
    Ryan Sarver replied 13 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
