Activity Forums Apple Final Cut Pro Legacy multicam dont believe the hype???
  • multicam dont believe the hype???
    Posted by Paul Nevison on November 16, 2005 at 8:25 pm
    Hey
    having a few issues with multicam – basically can’t get the multiangle view to play back 6 streams of 10 bit PAL SD digibeta footage. it drops frames or plays back the streams in the view incredibly slowly – definetly not as advertised. My raid is plenty fast enough to handle this i would have thought. I’ve gone through the tutuorial and have selected all the options suggested…can anyone think of a piece of the puzzle im missing here….
    ps using an Infortrend 8 bay SATA II fibre raid (raid 5)
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
    BMD Decklink Extreme
    Paul Nevison replied 20 years, 10 months ago 6 Members · 11 Replies
  • 11 Replies
  • Mark Raudonis
    November 16, 2005 at 8:31 pm
    Try this.
    Forget multicam. Create six “pictures” in picture in a timeline. Playback. Does it work?
    If not, your problems have more to do with through-put on your raid than anything with Multi-cam.
    Six streams of 10 bit uncompressed is a pretty heavy load. I think this is more a drive issue than anything to do with multicam.
    Mark
  • Dave Jenkins
    November 16, 2005 at 9:40 pm
    I just did a test with 8 bit uncompressed NTSC and was able to get to 6 angles, no higher. We are running a huge raid that clocks at 250 mb’s read & write. I had the same problem when I went to 8 angles and above.
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO & LA
    Huge 1.2 Raid
    FCP 5-OS X 10.4.1-QT 7
  • Paul Nevison
    November 16, 2005 at 11:01 pm
    really???? i’m not in the edit suite at the moment but the throughput should be cranking – it’s a brand new raid. so how is it supposed to work with HD as in all the apple demo’s???
    I have a nine camera live music gig to cut – the reason i upgraded was because i thought FCP 5 would be up to the job…seems not the case.
    would it be worth offlining at dv rez for the multicam then recapture at full D1 rez after ive done the cuts?
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Slack Alice
    November 17, 2005 at 12:00 am
    I ran many tests for a pilot project at a high profile manufacturer in order to test various different networks running with multistream thoughputs. We had a massively fast drive to rule that out of the equation.
    There are many parameters affecting your throughput not just drive and pipeline, these are in no particular order:
    CPU
    RAM
    Bus speeds
    Processor caches
    Also the set-up for multicam has several steps that you need to follow in order to get the greatest efficiency. The one that always gets me is forgetting the anamorphic sequence setting if the media is anamorphic – you should get a dark green or dark grey colour in the render bar in FCP if all is well. If not then you are pushing the Mac to its limit.
    Best of luck
    Alex Snelling
    Apple Certified FCP Trainer
    London
    Alex Snelling
    Slack Alice Films
    London
    http://www.slackalicefilms.co.uk
  • Michael Alberts
    November 17, 2005 at 4:25 am
    6 streams of 10bit PAL. That woudl be 25MB x 6 = 150MB sustained read speed. Add in some CPU overhead. What are your speed readings on your RAID? Remember, you need to look at the Sustained rate, not peak.
    Apple was able to do nine steams of HD due to the fact that it was DVCProHD at 100mb/sec per steam. That’s only 9x8MB/sec coming off a Xserve RAID.
    Michael Alberts
    Ambidextrous Productions, Inc.
  • Paul Nevison
    November 17, 2005 at 3:02 pm
    its all in the fine print!!! I will do the speed test on our raid to see what sustained rates we are getting – dissapointing that this feature is really only for DV work.
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Dan Riley
    November 17, 2005 at 3:42 pm
    Why do your multicam at full rez?
    I do my 5 camera SD projects at DV level first.
    I have no issues with playback speed.
    When the offline is done, you uprez.
    I’ve produced 3 half hours with FCP’s multicam
    feature this way. These were projects with
    over 30 hours of footage, 4 hours of which were a
    5 camera studio shoot.
    I’ve edited multicam for many years with AVID.
    Apple’s implimentation of this feature in FCP
    Is not perfect but it’s very good and will get better.
    Even with AVID, you would not do a multicam workflow
    like you are suggesting.
    Dan
  • Paul Nevison
    November 17, 2005 at 3:50 pm
    yeah im a bit of a full rez junkie – with advances in computer speed etc it has become possible to work in online quality from the start for many projects now – was looking forward to saying goodbye to offline ugliness – but may not be quite there yet!
    have you found uprezing with the FCP Media Manager stable? I know there have been issues with the MM with clips that have had speed changes etc… just wondered how the experience has been uprezing multiclips etc…
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Paul Nevison
    November 17, 2005 at 3:57 pm
    according to the blackmagic disk speed test i am getting a read data rate of 168.9 mb/s and a write of 146.4 mb/s
    in the 10 bit YUV 4:2:2 category for PAL I’m getting 160 mb/s read and 138 mb/s fir write
    how does that sound to you guys?
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Dan Riley
    November 17, 2005 at 5:47 pm
    About Media Manager….
    no, it does not do speed changes or reverses. So, do your offline with them,
    then make a note to go put those shots back to normal before the uprez,
    then go back and add back the speed changes. For me this is about
    five or six shots per half hour show. For some people who use alot of
    speed changes etc., of course it would be more trouble. Still frames
    are a yes and no situation. Most of the time they come through
    but sometimes they don’t. Of all the things I’d like to see fixed with FCP,
    MM is at the top of my list. However I still have relatively painless uprez
    because I know the limitations and work within them.
    As for multicam shots and MM, no problem. There is a check box
    you will see in the MM process that asks you if you want all the
    angles of a multiclip or just what you used. I only uprez the shot I used, otherwise
    you are talking a much larger uprez. This is the point of the offline.
    That’s where you make those decisions. This is the same thing AVID does.
    Finally, use this link as instructions for your uprez
    and you will be fine.
    https://www.kenstone.net/fcp_homepage/basic_onlining_jordan.html
    Dan
