Activity › Forums › Apple Final Cut Pro › Multicam colour (sorry color!)
  • Multicam colour (sorry color!)
    Posted by James Ewart on May 22, 2014 at 4:08 pm
    Hi all
    I’ve got a multi cam piece to edit and for one of the cameras (handheld B roll stuff) I have decided to use a Pleasantville effect. Incidentally how much more user friendly is this kind of thing to do in X compared to 7? A doddle. I really think the Avid community over here hate FCPX because they are scared of it.
    Anyway rather than apply it shot by shot in the multi can sequence I opened the multi cam clip and applied the effect to all of that camera. Perfect!
    Except now I would like to take it our of a few of the shots at the beginning of the clip and I cannot dial the effect int eh multi cam sequence itself. It seems to be overridden by the fact I have applied the clip to the entire camera.
    Puzzling … any thoughts?
    James
    http://www.jamesewart.co.uk
    James Ewart replied 12 years, 4 months ago 4 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    May 22, 2014 at 4:13 pm
    Blade the angle and take the color off.
  • James Ewart
    May 22, 2014 at 5:38 pm
    Hi Jeremy
    I’m not explaining very well because I don’t know what the view is called when you double click on the multi cam sequence. But it is in that viewing mode that I have made the colour correction.
    So when back into multi cam edit mode I cannot un colour correct the shot in question but have no way of telling which shot I want to take the colour off when in the ‘view all’ mode having double clicked.
    Does that make sense?
    thanks
    James
  • Jeremy Garchow
    May 22, 2014 at 5:49 pm
    The angle editor?
  • James Ewart
    May 22, 2014 at 5:53 pm
    Indeed. That’s the one “Angle editor” So I need to use t/c ref from the multi cam seqeunce and blade the clip in the angle editor to undo the colour correction.
    Now I would say that would be simpler if I could select the clip in the multi cam clip and adjust it there or “turn off” the colour correct.
    no great shakes I guess
    many thanks
  • Jeremy Garchow
    May 22, 2014 at 5:56 pm
    Yes. Since the color is added to the whole angle, you have to take it off of only the parts you need, and to do that you need to create those parts in the angle.
    Jeremy
  • James Ewart
    May 22, 2014 at 6:05 pm
    FCPX is so cool it has made me a bit lazy…the more it gives the more I want!!
  • Bret Williams
    May 22, 2014 at 6:16 pm
    Why not duplicate the angle, one with color effect, and one without. Then you can simply change angles in the sequence. No futzing about all the blading and match framing, etc.
  • Charlie Austin
    May 22, 2014 at 6:22 pm
    [James Ewart] “the more it gives the more I want!!”
    lol. Actually, when “stepping into” a Multiclip or Compound Clip, having the playhead “stick” on the frame relative to where it was in the project is something I really hope shows up at some point…
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • James Ewart
    May 22, 2014 at 6:24 pm
    Bret you have lost me there
  • Bret Williams
    May 22, 2014 at 6:46 pm
    In the angle editor, instead of slicing up the angle and removing the color effect, just duplicate the angle, and remove the color effect from the duplicate angle. Then you can go back to the sequence and “switch” between the angle with the color effect or not like it was a different camera angle.
