Multicam clips appear offline in Resolve 16 when importing FcpX timeline
Hi there, posting here for the first time. I am not sure if this is a basic issue or not, but I have done some searching over the web and havent found an appropriate solution, so I hope you guys can help me with this issue.
I have edited and picture locked an exstensive multicam sequence in Final cut Pro X.
I wished to proceed with colour correction in Resolve 16 and exported XML of the timeline. Upon importing the timeline in Resolve, the sequence was there, but all the multicam clips appeared to be offline. I got the “x out of x clips yet to be found” message. I tried to relink the clips manually by pointing to the media location of the original files but nothing happened.
The issue must be with how XML describes multicam clips and how Resolve interpretes, since importing the same XML timeline to Fcpx works without issues.
I also read somewhere that Xml renders and prepares its own media files for references, separate from the original media, but wasnt able to find the physical location of the XML media.
I do all my postproduction work on MacOS.
I hope anyone could direct me to a suitable anod not time consuming solution for the issue.
And maybe point to articles discussing how XML files are prepared and read between mentioned post production softwere.
Thanks a bunch for all the help, Maatjas
