Activity › Forums › Adobe Premiere Pro › Multicam blank – poor design
  • Multicam blank – poor design
    Posted by Oliver Peters on February 25, 2016 at 4:06 pm
    OK, here’s a situation that appears to go back years, so it’s clearly a Premiere Pro design issue.
    https://forums.creativecow.net/thread/3/879413
    (corrected from original entry) In the current version, the target track must match the track onto which the multicam clip (a nested sequence) has been edited. Therefore, if the clip is on V2 and target tracks V1 and V2 are enabled, you won’t see the cameras in the preview. If you turn off V1, they will appear. It seems like this is a bad design. You should be able to preview independently of the enabled target track. Or at the very least there should be a preference setting to follow the targets or not.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Andrew Kimery replied 10 years, 7 months ago 3 Members · 2 Replies
  • Herb Sevush
    February 25, 2016 at 9:54 pm
    [Oliver Peters] ” so it’s clearly a Premiere Pro design issue.”
    Yes, this is a bad design choice. The idea that the lowest targeted track, as opposed to the highest, engages all the multicam features makes no sense whatsoever. Better than that of course would be to default to the highest track without needing to target it, the FCP Legacy method, UNLESS a lower track were targeted. This would give you the most intuitive response while also giving you a way to over ride for special needs.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
  • Andrew Kimery
    February 26, 2016 at 12:09 am
    Yeah, I don’t get why it’s ‘bottom up; instead of ‘top down’ either.
