Activity Forums Apple Final Cut Pro Multicam audio pitch changed/playing slower?
  • Multicam audio pitch changed/playing slower?
    Posted by Dondré Gumbs on April 10, 2017 at 4:35 am
    I’m having a problem with the audio (music) of a multicam clip. Inside the angle editor, the audio plays at the right pitch. However, once I put it in the storyline and cut to the audio, it plays at a lower pitch. When I place the multicam clip in another project’s storyline, however, it plays at normal speed/pitch. I have a few more multicam clips in the project that the audio is changing and being strange, but those clips’ audio are fine. Can someone explain what is happening and how to fix this?
    Dondré Gumbs replied 9 years, 5 months ago 1 Member · 2 Replies
  • Dondré Gumbs
    April 10, 2017 at 4:58 am
    This is an example of what I’m talking about. I detached the audio from the multicam clips so that it’s easier to see. The top audio is the original, correct speed/pitched audio, and the bottom is the incorrect one. I put the clips to start around the same time, but gradually towards the end, the clips start to desync (the bottom clip gradually slows?).
  • Dondré Gumbs
    April 10, 2017 at 6:01 am
    I figured it out! It was because my multicam clip’s frame rate was 25, but the project’s was 23.97! I was hoping there was a way to change the frame rate of a multicam clip, but it seems like there isn’t, so I will just remake the multicam clip.
