Activity Forums Apple Final Cut Pro Multicam Audio Editing is A Major Pain
  • Multicam Audio Editing is A Major Pain
    Posted by Ken Bennett on January 1, 2017 at 12:52 am
    I have a 2-camera ceremony where cam1 has 2 audio sources and cam2’s audio for syncing only. So after I do my multicam edit I have my Multicam clip and my Project.
    I need to edit each audio input from cam1 for balance and tweaking and switching each one off where necessary. I can not Detach or Expand my audio in the Multicam clip. In the Project I can, but there are a 100 cuts between each camera forcing me to edit each cut’s audio separately. This of course would take hours. There has to be a much fast way to edit audio in Multicam shoots.
    Suggestions? Tutorials?
    Thanks.
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
    Jeff Kirkland replied 9 years, 8 months ago 3 Members · 2 Replies
  • Noah Kadner
    January 1, 2017 at 7:54 am
    Not sure exactly what you mean- but you can switch video only so that the audio track is continuous across cuts which should make things much easier if the audio track is without issues.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Jeff Kirkland
    January 1, 2017 at 10:00 pm
    Select all the multicam cuts in the project and make them a compound clip. Show audio lanes and you will have all your audio reassembled into continuous tracks.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
