Activity › Forums › Apple Final Cut Pro › Multicam audio
  • Multicam audio
    Posted by James Ewart on March 26, 2014 at 7:19 pm
    To my horror I have found I have accidentally set the default audio of a multi cam clip to the wrong audio sauce and then cut the clip.
    Only four minutes ling three cameras but a massive pain.
    Is there a way if correcting this across the project in one go rather than shot by shot anybody know please?
    Many thanks
    James
    http://www.jamesewart.co.uk
    Bret Williams replied 12 years, 6 months ago 2 Members · 2 Replies
  • James Ewart
    March 26, 2014 at 7:41 pm
    I had hoped by disabling the offending cameras audio in the channel configuration in the inspector might solve problem but it seems not.
    I’ve been a bit of an idiot.
    Switch audio shot by shot for every clip?
  • Bret Williams
    March 26, 2014 at 9:41 pm
    On a quick test I was able to switch multiple clips in the inspector in the channel configuration. The only gotcha seems to be that all the choices have to be from the same multi cam clip.
    So for example the inspector says 3 selected clips. 2 of the three channels are highlighted, but with a dash in the checkbox. I simply uncheck the dash on the channels I don’t want. Then recheck the dash of the channels I do want. Then when I check back in the sequence, they’re all the same channel.
    YMMV.
