Activity › Forums › Apple Final Cut Pro › Multicam and trimming
  • Multicam and trimming
    Posted by Oliver Peters on February 8, 2012 at 1:29 am
    FYI – if you slip/slide a clip from a multicam group on the timeline, it affects all the angles within. The good news is that sync is maintained. The bad news is that you can’t easily slip a shot that may need to be adjusted differently in relationship to the audio track or the surrounding cuts. Seems like there needs to be a “collapse multiclip” function as in FCP 7.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Oliver Peters replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
