Activity Forums Blackmagic Design multibridge/decklink proHD Audio distortion
  • multibridge/decklink proHD Audio distortion
    Posted by Sean Davison on May 13, 2006 at 6:07 pm
    I’ve just set up a new Edit suite with Quad G5, Decklink ProHD and Multibridge. Everything works fine but I seem to be getting audio distortion and clicks and pops that sounds a bit like an audio word clock issue. I’m monitoring via the Phono out on the multibridge into the “tape in” (line level) on a Mackie VLZ
    Sean Davison replied 20 years, 4 months ago 3 Members · 4 Replies
  • Bob Zelin
    May 13, 2006 at 10:59 pm
    plug into the 1/4″ Line input (not XLR) on your VLZ, and you will have no distortion problems. Yes, you will have to spend $5.00 at Radio Shack, but what is more important – lunch, or no distortion?
    Bob Zelin
  • Sean Davison
    May 15, 2006 at 8:56 am
    Thanks, I’m plugged in to the tape in on the mackie which I’m sure is a line signal – I’m still getting what sounds like a word clock error even when nothing is playing and FCP isnt running- there’s a kind of static crackle. Ive isolated it to the multibridge as the sdi audio from the video monitor is clean – It’s just the multibridge! Is there a factory reset?
    Im using decklink drivers 5.5.1 with OS 10.4.6 and qt 7.0.4 and multibridge utility 5.5.1
  • Anthony Vamvakitis
    May 16, 2006 at 4:55 pm
    I think i have a similiar issue. A warbling distortion sound that comes and goes. I stop the playback and then it goes away, but comes back intermittently… Is this what you’re talking about or is yours constant.
    And by the way, I don’t know how to solve this.
  • Sean Davison
    May 16, 2006 at 5:26 pm
    mine is constant and it is definitely a multibridge issue – Im replacing all my cabling tomorrow hoping that helps as Im using a couple of old SDI Cables! Interestingly it goes when I choose SDI
