Activity Forums Blackmagic Design Multibridge Pro/Audio Issue
  • Multibridge Pro/Audio Issue
    Posted by Peter Stewart on March 9, 2008 at 11:39 am
    I’ve done search for this problem and found a few posts discussing it, but none seem to have any solutions, so I thought I’d raise it again (presumably it’s the same issue).
    I’ve been mastering to HDCam using a HDW2000 using HD-SDI, with the output from the deck feeding a JVC DTV24L1U monitor. I keep hearing a persistent popping sound where ever there is audio on the timeline, where there is no audio (empty audio track) there is no popping.
    I double checked through the headphone monitor on the deck and can hear the popping, so it’s not a problem between the deck and monitor.
    When I feed the HD-SDI output straight from the multibridge to the monitor directly there is no problem with the sound, it’s clean as a whistle.
    The week previous I mastered to Digibeta (using the multibridge internal SD down conversion) and had no problems with the sound on that occasion.
    As yet I’ve not installed the latest MB software as I was in the middle of a project, eventually I just used the analogue outputs from the MB to the deck, which again was delivering clean audio.
    Has anyone else had the same problem and have a solution?
    Kind Regards
    Peter Stewart
    Freelance Editor (UK)
    In Production : Legacy of War (ITV/WNET), Imaginary Summer (Feature Narrative)
    Kristian Lam replied 18 years, 6 months ago 2 Members · 1 Reply
  • Kristian Lam
    March 11, 2008 at 12:29 am
    Hi Peter,
    Are you using any kind of video reference? Is the HDCAM set to use the video input as the reference source?
    regards
    Kristian Lam
    Blackmagic Design
