Activity Forums Blackmagic Design Multibridge Pro, XDCAM & Dropped Frames
  • Multibridge Pro, XDCAM & Dropped Frames
    Posted by Aaron Cadieux on January 14, 2009 at 7:02 pm
    Hello,
    OK… So the folks at Blackmagic claim that you can edit XDCAM files natively in Premiere Pro CS3 using the Multibridge Pro. I have some SP 1080i 59.97 footage that I shot with the EX1. I converted the files to mxf files using Sony’s Clip Browsing 2.0 software. I then open a Blackmagic 8-bit 59.97i preset project in Premiere. I bring the XDCAM files in successfully. However, if I bring a clip onto the timeline and try to play it, it drops a frame during playback within seconds. What’s the deal here?
    -Aaron Cadieux
    Aaron Cadieux replied 17 years, 7 months ago 4 Members · 5 Replies
  • Don Greening
    January 14, 2009 at 7:11 pm
    Perhaps the transfer rate of your media drive(s) not keeping up? Just guessing, since I don’t use Premiere.
    – Don
  • Deleted User
    January 14, 2009 at 8:48 pm
    Hello Aaron,
    I will second Don about your Media drives not keeping up. Are you using a raid 0 hard-drive config with 2 or more drives?
    Leo
  • Bob Zelin
    January 15, 2009 at 1:28 am
    everyone here is correct. What are your disk drives. If you are using the internal hard drive of your MAC or PC, or are using a FW400 drive, you will FAIL, and get dropped frames, or stuttering playback.
    Bob Zelin
  • Aaron Cadieux
    January 15, 2009 at 2:41 pm
    Yes I am using a 2TB RAID 0 Hard Drive.
  • Aaron Cadieux
    January 15, 2009 at 2:44 pm
    An interesting side note. These dropped frames only happen when I try to work with the following:
    Motion JPEG in a Blackmagic Motion JPEG Project
    HDV in a Blackmagic 8-bit Project
    Oddly enough, if I capture 8-bit HD via the SDI out on the EX1 and load it into a Blackmagic 8-bit preset project, the video plays as smooth as silk, and the files I am dealing with in that case are HUGE!
