Activity Forums Apple Final Cut Pro Legacy Multibridge Pro update causes footage to play too fast
  • Multibridge Pro update causes footage to play too fast
    Posted by Scott Devlin on September 3, 2009 at 1:56 pm
    I just installed the latest Multibridge Pro software on my Mac Pro, and now everything in Final Cut has no audio and plays back way too fast. What would cause this?
    David Perry replied 16 years, 11 months ago 4 Members · 3 Replies
  • Ray Chung
    September 4, 2009 at 12:41 am
    Need more info. What format are you cutting in FCP, what Video/Audio Playback setting are you using? Is it playing fast on the timeline/viewer in FCP, or only via video out through the Multibridge?
    What OS X, etc.?
  • Steve Oakley
    September 4, 2009 at 3:46 am
    is your TL at 29.97 and your video out at 59.94 ?
    and did you trash FCP prefs to start with ?
    Steve Oakley
    DP • Editor • VFX Artist
    http://www.practicali.com
  • David Perry
    September 17, 2009 at 8:41 pm
    Hello,
    I had the same problem, exactly. The fix is to remove the AJA IO/HD utility program from the Application Folder and reboot. Now, no problems. They just can’t both be on the machine at the same time.
    David Perry
    David Perry
    Carmen Productions
    Leesburg, VA
