Activity Forums Blackmagic Design Multibridge Pro Messing Everything Up
  • Multibridge Pro Messing Everything Up
    Posted by Aaron Cadieux on March 31, 2008 at 2:30 am
    Hey All,
    Big problems with my Multibridge Pro. Projects created in Premiere Pro 2.0 using the Decklink presets seem to work fine. However, projects that already existed on my system before I installed the Multibridge now have major playback problems. Upon playback I get non-stop dropped frames in the source monitor, and ‘video stopping’ issues (where the video stops and the audio keeps going) when I play back what is on the timeline. Also, if I import an HDV clip into an SD project, the HDV clip gets all squished to 4×3 in the source monitor and won’t play back without dropping a frame. When I unintall the Multibridge Pro and Decklink software from my PC, ALL of these problems dissapear. Even the HDV clip brought into an SD project displays in the proper aspect ratio in the source monitor, AND it plays back without dropping frames. What is going on here? I can’t put my finger on it. Am I not supposed to use anything but the Multibridge for capturing and projects once I have it installed????
    Aaron Cadieux
    Aaron Cadieux replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
