Activity › Forums › Blackmagic Design › Multibridge extreme – decklink control = losts communications – FCP = dropped frames?
  • Multibridge extreme – decklink control = losts communications – FCP = dropped frames?
    Posted by Justin Tan on April 5, 2006 at 1:12 am
    Not sure if this is a MBE issue or not, so this has also been posted on FCP forum
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=8&postid=888126
    When I digitise via the decklink control – the capture utility stops at a random point and states it does not have communications. I do this a few times and it keeps happening, albeit at different points.
    The same thing happens in FCP – but in FCP it reports it as dropped frames.
    Shortclips capture fine, but long clips give this problem.
    The funny thing is that it played out a 20minute clip quite fine – so I don’t think there is anthing to do with the remotes or deck.
    I have 5.4.1 drivers installed I believe.
    Justin Tan replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
