Activity Forums Blackmagic Design Multibridge Exreme only for viewing video on 30″ display
  • Multibridge Exreme only for viewing video on 30″ display
    Posted by Macscorpio on February 7, 2007 at 10:14 am
    Please help,
    I would like to purchase BlackMagic Multibridge Extreme for monitoring video from HD deck on Apple 30″ display. I would not be able to connect Multibridge Extreme PCIe card on a computer. Is this possible??
    Thanks a lot for help.
    Macscorpio replied 19 years, 7 months ago 3 Members · 6 Replies
  • Chris Borjis
    February 7, 2007 at 6:04 pm
    If all you need is for monitoring perhaps the HDLink is all you need?
    (this is the dvi-d output of a multibridge extreme)
  • Macscorpio
    February 7, 2007 at 10:05 pm
    HDLink does not supports 30″ displays, only 23″, and that is the reason why I want to use MultiBridge.
  • Chris Borjis
    February 7, 2007 at 10:13 pm
    I’m surprised they have not made that possible fo[macscorpio] “HDLink does not supports 30″ displays, only 23″”
    wow, i thought they would have fixed that with a firmware upgrade by now.
  • Kristian Lam
    February 7, 2007 at 11:20 pm
    [macscorpio] “I would like to purchase BlackMagic Multibridge Extreme for monitoring video from HD deck on Apple 30″ display. I would not be able to connect Multibridge Extreme PCIe card on a computer. Is this possible??”
    Yes. the Multibridge Extreme will work as a stand alone converter. You might need to set it up while connected via USB using the included Multibridge Utility software but once that is done, the settings will stick and you don’t have to have it connected to your PC/Mac anymore.
    regards
    Kristian Lam
    Blackmagic Design
  • Kristian Lam
    February 7, 2007 at 11:21 pm
    [Borjis] “wow, i thought they would have fixed that with a firmware upgrade by now.”
    Hi Borjis,
    Not possible as the hardware required is different and will not be upgradable by firmware. The 30″ requires a dual link DVI-D connection while the HDLink has single link DVI-D.
    regards
    Kristian Lam
    Blackmagic Design
  • Macscorpio
    February 8, 2007 at 8:00 am
