Activity › Forums › Blackmagic Design › Multibridge compatible with Avid Xpress Pro?
  • Bob Zelin
    March 15, 2006 at 2:00 am
    to do what with it ? To use it as a stand alone converter, so you can get SDI into the analog component inputs ? I have a better idea – how about learning FCP, and just use it as your REAL video capture board, and have a great edit system.
    Of course, you could buy an Adrenaline.
    Bob Zelin
  • Matthew Beall
    March 15, 2006 at 4:26 am
    I have Vegas now, and everything seems to be working great..
    The system is a dual 3Ghz Xeon w/ DecklinkHD and Multibridge and about 2 hours of HD hard disk space.. Will the Avid software not see my hardware for deck control, capture, etc? Will FCP? We need to be able to capture from Panasonic Varicam 720p and HDV, as well as SD sources..
    -Matthew
  • Kaspar Kallas
    March 15, 2006 at 5:36 am
    Avid will work only with AVID hardware – you can use MB only as converter box – thus no deck controll
    you can use MBE or MB and Decklink combo with FCP, Primeiere Pro and Vegas
    -Kaspar
