Activity Forums Adobe Premiere Pro multi track select tool in premiere pro
  • multi track select tool in premiere pro
    Posted by Bodybuildingbs on August 14, 2005 at 6:32 pm
    Is there such a thing as the multitrack select tool in pro..there was one in 6.5 where you could nudge a track down a little to do an insert.
    When I try to do an insert in pro, it just overlays the clip cutting off the start of the end clip.
    Please advise.
    Steven L. gotz replied 21 years, 1 month ago 2 Members · 1 Reply
  • Steven L. gotz
    August 14, 2005 at 7:39 pm
    The default action is Overlay. You need to learn to use the Modifier keys in Premiere Pro. You will notice that there are fewer tools – but the tools are really still there. They are just combined with other tools and require the use of a Modifier key. In this case, the Ctrl key changes overlay to insert.
    Single Track is selected by using the “M” key. Once selected, use the Shift key to change from single track to Multi-Track.
    If you select a tool, like the Select tool (V), and hover over a clip in the sequence, you will see instructions in the status bar to use modifiers. As you press each modifier, the instructions change.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
