Activity Forums Adobe Premiere Pro multi track audio adjustment
  • multi track audio adjustment
    Posted by Tim Taylor on April 30, 2008 at 3:48 pm
    I have several audio tracks in a sequence in PPro CS3, all of which are at varying degrees of volume. As they are also on different tracks, I can’t simply adjust the master volume for that track as some of the audio I need to make louder, and some quieter.
    Is there a way to have all the audio peaks at a certain level so that all the audio tracks are of equal if not similar volume?
    I know there is a way to sort out the peaks in Final Cut Pro, so is there a method in Adobe’s offering??
    Thanks in advance.
    Tim Taylor replied 18 years, 4 months ago 2 Members · 2 Replies
  • Mike Velte
    May 1, 2008 at 10:42 am
    You can “Normalize” an audio clip, but not the track. Right click on each audio clip and choose Audio Gain and then the Normalize button.
    https://www.video2stream.com
  • Tim Taylor
    May 1, 2008 at 4:54 pm
    Hmmm… another reason to consider FCP when my next equipment change is due. C’mon Adobe, give us a COMPLETE product and not something so half hearted…
    Thanks anyway Mike – BTW, the site you link to in your sig is broken? No index.html it says…
