Activity Forums Audio Multi media headset
  • Multi media headset
    Posted by Brian Reynolds on March 3, 2008 at 11:03 pm
    Does anyone know of a circuit to power the condenser mic from a multi media headset?
    I wish to run the mic as a talkback mic and will need to power via batteries this i know…
    Or can 48v phantom be tricked down to get the 3v needed for the mic?
    Many thanks
    Brian Reynolds replied 18 years, 2 months ago 2 Members · 2 Replies
  • Ty Ford
    March 4, 2008 at 4:59 pm
    Hello Brian and welcome to the Cow Audio Forum.
    Here’s the problem. Phantom Power is applied to both sides of a balanced mic, and not to the ground. Multimedia mics are generally unbalanced. If you apply Phantom Power to the shield and hot lead, you’ll toast the mic.
    You need a mic with a balanced output to use Phantom Power properly. The Countryman E6 with XLR termination will work fine
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Brian Reynolds
    March 4, 2008 at 11:14 pm
    Thanks Ty,
    I am aware that a multi media headset is unbalanced … I was just wondering if anyone has come up with a (48v phantom to 3v unbalanced adaptor)…
    I have in my kit a (48v phantom to 12v T power adaptor) its just a bit tricky to get open to see whats inside….
    The countryman E6 looks good but i may need 20 of them, but not that sort of budget.
    Cheers
