Multi GPUs with After Effects CS6
https://blogs.adobe.com/aftereffects/2012/05/gpu-cuda-opengl-features-in-after-effects-cs6.html
I’m looking into putting 3 GTX580s into a machine to use with After Effects. According to what I’ve read After Effects should be able to utilize all three of them.
Is anyone else running a setup like this? Are there any hitches to using multi GPUs (all the same model/specs) in After Effects or will it really be 3x the efficiency?
