Activity › Forums › Apple Final Cut Pro Legacy › multi-format woes
  • multi-format woes
    Posted by Kurt Uebersax on October 16, 2009 at 2:47 am
    I have a unique project, looking for some help- I have “behind the scenes” footage from a conference shot in SD 4:3 on a Sony PD170. Simple enough, until the client gave me 2 hard disks of HD 16:9 images also used during the conference from a separate video setup (the Image Mag/Closed Circuit Feed), and they want me to mix the images. So far my plan seems to be set up my sequence for the SD 4:3 (lowest of the qualities), and render in the HD 16:9 clips as needed. 3 questions:
    1. Am I on the right track?
    2. When exporting (DVD is end deliverable), is there a way to “conform” the entire piece to either 4:3 or 16:9? Ideally, I would love to give them a DVD of each if possible, and they can choose which they like.
    3. Suggestions on what compression (if any) I should use?
    I’m newer to using my FCP, Have 7.0.
    Best,
    Kurt Uebersax
    http://www.kjuproductions.com
    Kurt Uebersax replied 16 years, 11 months ago 2 Members · 2 Replies
  • Rafael Amador
    October 16, 2009 at 5:37 pm
    Hi Kurt,
    That’s the way.
    Work in a DV 4×3 sequence and resize the HD shoots as needed.
    You may get a better result if before rendering you set your sequence codec to DVCPro50 or better.
    [Kurt Uebersax] “2. When exporting (DVD is end deliverable), is there a way to “conform” the entire piece to either 4:3 or 16:9? Ideally, I would love to give them a DVD of each if possible, and they can choose which they like. “
    once you have imported the MPEG-2 to DVDSTP, you need to check the clips as 4×3.
    [Kurt Uebersax] “3. Suggestions on what compression (if any) I should use? “
    The Compressor Presets are OK to start.
    rafael
    http://www.nagavideo.com
  • Kurt Uebersax
    October 16, 2009 at 8:29 pm
    Thanks Rafael, seems to be working!
    Best,
    Kurt Uebersax
