Activity Forums Apple Final Cut Pro Legacy Multi format timeline
  • Multi format timeline
    Posted by Tom Duncan on August 12, 2007 at 10:19 pm
    Has anybody noticed that multi-formats on a timeline results in image softness? I brought a few DVCPROHD clips into a DVCPRO50 timeline and the HD clips are kinda blurry. On a DVCPROHD timeline they look spot-on crisp.
    thanks, td
    Jerry Hofmann replied 19 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 13, 2007 at 1:29 pm
    You’ll need to render to see full res I’ll wager, and are you looking at the clips externally on a video monitor? That would be the only way to tell what you’re really getting…
    Also I’d suspect that down converting to SD from HD SHOULD look a bit softer than the original.
    Might try putting the mixed formats in a ProRes Sequence, and see if that improves things.
    Jerry
