Activity › Forums › Apple Final Cut Pro Legacy › Multi clip problem
  • Multi clip problem
    Posted by Ron Pestes on June 15, 2011 at 1:50 am
    I have been editing a 3 camera multi clip this afternoon and everything was working great. Then I let it render and when I came back, without changing anything the canvas and viewer both show the clip that is playing in the canvas instead of showing the 3 camera angles in the viewer. Play head is still set to “open”. When I pause playback in the canvas the 3 cameras return in the viewer. “Multiclip” playback is checked under RT settings. What has changed to cause this?
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Ron Pestes replied 15 years, 3 months ago 2 Members · 2 Replies
  • John Pale
    June 15, 2011 at 4:42 am
    [Ron Pestes] “Then I let it render “
    Now its playing the render file and not the clip. Select all the clips that got rendered and toggle control-B. This will disable and re-enable the clip, thus causing everything to unrender.
    You will want to disable auto rendering when using multiclip, as FCP considers this an effect.
  • Ron Pestes
    June 15, 2011 at 3:45 pm
    OK, that solved it! I did not know about control-B. Thanks a lot, you saved my day!
    Sony EX-3
    MacBook Pro
