Activity Forums Apple Final Cut Pro Legacy Multi clip freezing
  • Multi clip freezing
    Posted by Martin Deeney on July 19, 2011 at 5:06 pm
    Hi can anyone help me with some advice on
    multi clips in fcp? They keep freezing on me, probally as i’m using pro res clips which are too big. Is there a way of using proxy files to edit and then upscale? I have read the all the posts on Creative Cow that i can find, but none mention how to do it with multi clips, once i’ve pluralised my clips i’m making self contained files for each angle and then making a multi clip from they files.
    Any help is much appreciated.
    Martin
    Martin Deeney replied 15 years, 1 month ago 2 Members · 4 Replies
  • Everest Mokaeff
    July 19, 2011 at 7:14 pm
    Make sure you have multiclip playback checked. Take a look under RT/Safe Playback options. If you don’t have external raid it’s unrealistic to have more than 2 HD prores HQ streams played realtime.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Martin Deeney
    July 19, 2011 at 7:37 pm
    Hi, thanks for answering, all those sort of things, settings etc are all fine, i’m using sata drives, the problem is how do i edit in proxy and then covert to pro res using the individual files that the multi clipis made up of?
  • Everest Mokaeff
    July 19, 2011 at 8:23 pm
    Create Proxy/LT ProRes from original media, same frame rate, same resolution. Compared to your final HQ clips proxy must differ only in terms of bitrate. Afterwards reconnect to original media – specific technique of how to do it is up to you. Check some tutorials on this site on tapeless workflow and proxy media management.
  • Martin Deeney
    July 19, 2011 at 9:06 pm
    Thank you Everest, appreciated.
