Activity Forums Apple Final Cut Pro Legacy Multi-Clip Exports with Identical Templates
  • Multi-Clip Exports with Identical Templates
    Posted by Elliot Grimm on August 29, 2012 at 5:10 pm
    For my work, I need to take a lot (100ish) of short instructional clips and attach a still image to the end of each so that it displays for around ten seconds. Lastly, there is a YouTube page that I will be uploading all these too, as well. I figure the format then should be flv or mp4.
    I looked in the FCP Manual and saw the section “Exporting Groups of Clips and Sequences with Share” section, but I was hoping someone might be able to confirm that this is the correct and best way to get this done. Perhaps there’s a more automatic (less manual?) way to attach a 10-second still to 100 videos for youtube?
    Thanks for any help or direction!
    Elliot Grimm replied 14 years ago 2 Members · 2 Replies
  • Steve Eisen
    August 30, 2012 at 1:45 pm
    If each still is different, you will have to do that manually.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Elliot Grimm
    August 30, 2012 at 2:41 pm
    Each still is identical. I may still have to manually attach it as an outro to each one, as I don’t know how to add an automatic outro-still to the end of each exported clip.
    If you can’t answer for sure, maybe you could tell me if batch export is the way to go for multiple clip/sequence exporting? I’m new to this process in FCP.
