Activity Forums Square Box CatDV Multi-Check Box
  • Scott Goddard
    April 30, 2012 at 12:02 am
    Hi Geof,
    Yes its a little confusing, but the reference guide does explain it.
    Basically you create a multi checkbox not in the pick list section but in the ‘user column’ section under preferences.
    Type your list of checkboxes that you want like this, for example lets say you wanted to checkbox what the weather was like on a shoot, your user column name will look like this:
    Weather:Sunny:Cloudy:Raining:Thunder:Snowing etc..
    So the first word is the name of the field and then the colons separate the names of the checkboxes. Then you just need to choose Multi Checkbox from the type column and you are good to go…
    Scott
    Néo Vérité Limited
    http://www.neoverite.com
