Activity Forums Apple Final Cut Pro Legacy Multi Camera Question
  • Multi Camera Question
    Posted by Patrick Morrow on October 25, 2005 at 7:54 pm
    Why does final cut stick after using multi cam and then later wanting to resume were I left off? It seems to lock up on the timeline or viewer window. Do I have to do the cutting in one sitting?
    Thanks!!!
    Patrick Morrow
    Tim Vaughan replied 20 years, 11 months ago 2 Members · 1 Reply
  • Tim Vaughan
    October 25, 2005 at 11:45 pm
    I personally haven’t had this problem. I have created, edited, collapsed, uncollapsed with relatively little problem on that end. I did notice that (on mutliclips) when moving the capture scratch files from one drive to another, clips have a tendency to lose their affilition with the master clips, thus ending in “offline footage” even though everything is there. You have to manually go in and re-edit–that is, grab the in/out points from the “offline” clips and re-insert the same existing footage in. A real pain in the butt. That being said, I would doubt it if there are kinks that are individual to each person’s workstation. I do hope this works out for you, and sorry if I can’t be more of a help.
    Tim
