Multi Camera Multi Ki Pros
Hey Guys
I am working on a multi camera show
I want to start a knowledge base here for this type of jobI am currently doing a 4 camera job as Ki Pro & Data Manager,
I have 3 Ki Pros & 1 Ki Pro Mini
I am using an ethernet hub or switcher to connect through a computer
I was using gang recording until I updated the firmware for the Mini today.I restarted everything I can see the Mini in the browser but the Master just cant see the mini in gang record.
I can however use the mini as the Gang Master so I switched and made the Mini the master.
I do occasionally get dropped frame errors on the mini, thtas why I did the firmware update.
I will continue to add info as we go here.
