Activity › Forums › AJA Video Systems › Multi Camera Multi Ki Pros
Jeremy Garchow
May 10, 2011 at 7:37 pm[Joe Christofori] “So what causes the dropped frames ?”
Slow media?
Joe Christofori
May 10, 2011 at 8:01 pmIm using the sandisk 90mbs, which is in their pdf of approved media
sandisk extreme pro 64g and 32g -
Jeremy Garchow
May 10, 2011 at 8:25 pm[Joe Christofori] “Im using the sandisk 90mbs, which is in their pdf of approved media
sandisk extreme pro 64g and 32g”Got ya. Then you should be ok if everything is formatted/setup correctly. Perhaps you should contact tech support.
Jeremy
Joe Christofori
May 11, 2011 at 8:14 pmWe took the Mini out of the mix and things are much better today
Regular & Mini just dont work together well….. yet.im sure they will work it out.
Jeremy Garchow
May 11, 2011 at 8:30 pm[Joe Christofori] “We took the Mini out of the mix and things are much better today
Regular & Mini just dont work together well….. yet.im sure they will work it out.”
I concur.
