Activity Forums Apple Final Cut Pro Legacy Multi Camera Issue
  • Multi Camera Issue
    Posted by Patrick Morrow on August 4, 2007 at 2:34 am
    Does anyone know why my multi camera edit will sometimes not allow me to see the cameras in motion. I am in the gang mode but for some reason it will not work at times and all of a sudden it will all work again for no reason. I am editing in Final Cut 5.
    Thanks So Much!!!
    Patrick Morrow
    Tim Vaughan replied 19 years, 1 month ago 4 Members · 3 Replies
  • Tom Wolsky
    August 4, 2007 at 2:52 am
    You don’t want gang mode, you want open mode.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Dan Riley
    August 4, 2007 at 4:17 am
    Also, you can’t see multiclip angles if your timeline is rendered. (blue line)
    If you were editing and then decided to render the sequence because of
    effects or whatnot, now when you roll your sequence you will see the same
    picture in both the viewer and canvas. Just get rid of the render.
    You do that by clicking off the green button on the left side of the video track.
    Then click it on again.
    Dan
  • Tim Vaughan
    August 4, 2007 at 10:43 pm
    …And make sure you are running the sequence at the correct frame rate….
