Activity Forums Apple Final Cut Pro Legacy Multi-cam Sync issue
  • Multi-cam Sync issue
    Posted by David Rowan on June 27, 2012 at 6:04 am
    FCP 6.0.6
    4 camera multi-clips, DV-NTSC Anamorphic. MacPro, OS 10.7.4
    I have done this before on previous episodes of the same show.
    Lay down the multiclip in the timeline. Double click to open it in the viewer. In the canvas use the top-middle button to select sync. When you play the timeline you see the 4 clips play back in sync and you can begin switching angles. Right?
    The problem: When I double-clicked the clip so that it is open in the viewer, and sync it, rather than the usual 4 angles I only see the one, selected, angle. When I press stop it switches to the multi-cam view, and its in sync, but when I actually “play” the timeline I only see one, full screen, clip playing back in sync.
    I’m sure that I must have simply clicked on the wrong button somewhere, but I just can not seem to find it.
    Suggestions?
    Terry Leahy replied 14 years, 2 months ago 3 Members · 2 Replies
  • Shane Ross
    June 27, 2012 at 7:43 am
    In the RT menu on the timeline…select MULTICLIP PLAYBACK
    Shane
    Little Frog Post
  • Terry Leahy
    June 27, 2012 at 11:21 am
    I had this problem too. First I second what Shane said. The other problem can be if the clip rendered. Is there a green bar over the clip? If not go into your render files an delete the multiclip render file. Final cut will only show you the alternate angles during playback in a pre rendered state.
