Activity Forums Adobe Premiere Pro Multi-Cam Sequence Locked Up! Bug?
  • Multi-Cam Sequence Locked Up! Bug?
    Posted by Rob Davis on June 22, 2021 at 9:03 pm
    I have a multicam sequence that won’t let me move any clips, or drop new clips into it. It will only let me shorten/lengthen clips on the timeline. I get this cursor when trying.
    If I try to drag new clips into the timeline, I get a message in a box No Content Sequence In/Out Range but I have removed in/out points in timeline and in source window.
    No tracks are locked. I’ve tried every configuration of track targeting and patching. I also can’t copy/paste the clips to another timeline. It will let me highlight all the clips and drag them to the ‘new sequence’ button and then I can move them, but as soon as I make it a multi-cam timeline everything locks up again.
    I’ve seen this issue reported elsewhere without solution. Is it a bug?
    Im on 14.9.0
    PC – Windows 19042.1052
    Ben Johnson replied 3 years, 4 months ago 2 Members · 1 Reply
  • Ben Johnson
    April 25, 2023 at 2:55 pm
    Here’s your timely solution. If timecode runs over 24 hours. The clips lock up. Cut the clip that went over down to under 24 hours in the sequence, then copy and paste everything into a new sequence.
