Activity Forums Adobe Premiere Pro Multi-Cam Editing- tweaking angles in timeline after initial switches have been made
  • Multi-Cam Editing- tweaking angles in timeline after initial switches have been made
    Posted by Robb Bomboy on October 21, 2014 at 12:46 pm
    Hello,
    I’m trying to teach my students multi cam editing. We’ve made all our switches in the multicam editor. We have them marked in the timeline. We should be able to jest drag the ins and outs and adjust the switches, but It won’t work.
    Advice?
    Robb Bomboy replied 11 years, 11 months ago 2 Members · 4 Replies
  • Herb Sevush
    October 21, 2014 at 3:47 pm
    what version of Ppro are you using?
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
  • Robb Bomboy
    October 22, 2014 at 9:20 pm
    CS 6
  • Herb Sevush
    October 22, 2014 at 9:25 pm
    Robb –
    I’m using CC 2014 so I’m not quite clear on the differences, however you should be able to move the cut points of the different angles exactly the same as you move any other cut point on a timeline and you should be able to switch angles by keystroke command. What happens when you try to move the cut points with the rolling edit tool (or the selection tool with the command key modifier)?
    Herb Sevush
    Zebra Productions
  • Robb Bomboy
    October 26, 2014 at 4:29 pm
    Thanks! The selection tool +command did it.
