Activity › Forums › Adobe Premiere Pro › Multi-Cam Audio Missing
  • Multi-Cam Audio Missing
    Posted by Dan Chapman on June 3, 2013 at 8:18 pm
    In PPro CS6.
    I’m trying to edit with a two-camera multicam music performance with separately recorded stereo audio. Everything syncs up nicely with PluralEyes, but when I make my multi-tracks, PPro is only bringing in one track of audio.
    Am I missing a setting that will give me the Bass track, which is so important to make my cuts? Or do I have to drag it over from the original sequence, like I’ve been doing up till now? (This method creates linking problems later).
    Why can’t PPro just bring in the enabled audio tracks and have a way to cut muti-tracks as “video only”??
    Help please!
    Dan
    Ron Pestes replied 13 years, 3 months ago 2 Members · 3 Replies
  • Ron Pestes
    June 3, 2013 at 11:43 pm
    PP uses the first audio track selected when you make your multi-cam timeline. If you have several audio tracks mix them together so you only have one and then link it to the first video track that you select. I think this should work.
    ronpesteshdvideo.com
    JVC GY-HM600
    Dell M6600
    Adobe CS6 Production Premium
    MacBook Pro
    Apple Certified Master Pro FCS 2
  • Dan Chapman
    June 4, 2013 at 12:18 am
    Thanks Ron.
    Is this result any different than linking them and substituting the audio after the nested/multi is made?
    Dan
  • Ron Pestes
    June 4, 2013 at 3:20 pm
    I have not tried that but I think it should be the same. Not sure though.
    JVC GY-HM600
    Dell M6600
    MacBook Pro
