Activity Forums Adobe Premiere Pro Multi-Cam and Script Supervisor Notes Workflow Premiere Pro 6?
  • Multi-Cam and Script Supervisor Notes Workflow Premiere Pro 6?
    Posted by Eddie Fisher on May 24, 2013 at 5:57 pm
    Do any of you ever work with script supervisor notes? I am having an issue in that I have a multicam shoot, and script supervisor notes, and when I create a Multicam sequence, I no longer have a hard Source code to reference. I could go and add a Timecode effect for a visual, but I can’t even reference a code in the project window to see the “best take times” at a glance (there are a few hundred trigger pulls on 3 cams over 5 days of shooting). The timecode column is blank.
    I am so used to “Create Multi Clip, punch in a time code, scrub a bit for a good in, punch in an out, scrub, Mark Out, make the edit, Next one, etc.”.
    I am fairly new to PPro 6 but very fluent on both Avid (20+ years) and FCP (10+ years), and wondering if any of you have come up with a good workflow for any of this?
    I’m thinking I might need to do an “A” cam cut and drop my Camera cuts manually into the sequence?
    “Star Wars In 5 Minutes – For 5 Bucks – Since 1989”
    Drew Lahat replied 13 years, 3 months ago 2 Members · 1 Reply
  • Drew Lahat
    May 26, 2013 at 2:48 am
    My hunch would say “Prelude”. Haven’t had much personal experience with it, but it’s designed to process producers` and script sups` notes and integrate them with Premiere. It’s not gonna magically add a timecode input field to PPro, but perhaps you’d be able to get all the notes as markers you could navigate between.
    Might either help you with your current project or for future ones.
