Activity › Forums › Apple Final Cut Pro › Multi Cam
Multi Cam
Posted by Patrick Morrow on February 4, 2012 at 6:56 pmTrying to use multi cam in FCP X and when I make the multi clip it adds the 3 clips next to each other and it does not work. Please help!
Bat Sac replied 11 years, 12 months ago 5 Members · 6 Replies -
Tom Wolsky
February 4, 2012 at 8:16 pmHow are you syncing the clips? Using audio sync? Is there sound on all the cameras?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Coming in 2012 “Complete Training for FCPX” from Class on Demand
“Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press -
Patrick Morrow
February 4, 2012 at 9:44 pmHi Tom,
I have audio on all 3 clips. Strange thing the other clips work with multi clip only the tape based clips I need do not work, they only produce a clip with 3 clips side by side. Thanks!!! -
Jeff Kirkland
February 4, 2012 at 11:20 pmWhat settings are you using when creating the multi clip?
To leave a little less to chance you might try checking/changing the clip metadata – make sure each angle has a different name, make sure each camera has a different name / ID.
You can also try to manually create the angles in the multi clip angle viewer, drag the clips into the appropriate angle and then get FCPX to re-sync the clips from there.
Cheers
Jeff KJeff Kirkland | Southern Creative Media
video * audio * post * production
Melbourne, Australia -
Mikey Bouchereau
February 5, 2012 at 4:26 amChange from auto, and choose “clip” as your choice for Angles. Otherwise it will try to sync by camera.
This is meant to sync DSLR cameras. The nice part about the Angle option is that it chooses “camera” by default, so if you have 2 cameras say a Video Camera and a DSLR even though you may be syncing something like 5 clips (4DSLR and 1 Video Camera Stream) you only have 2 camera angles.
I ran into this problem when I was trying to multcam a music video shot with 2 cameras, we did multiple takes and it gave me only 2 angles, but sync’d them up. I then choose Clips and it then sync’d all 16 takes/angles.
Hope that helps.
Mikey B!
Download Free Effects/Transitions/Generators for Final Cut Pro X
Check Out My Sky Replace Tutorial
Patrick Morrow
February 5, 2012 at 6:31 pmThanks Mickey,
That worked and it worked great!
God Bless,
Patrick Morrow
