Activity › Forums › Blackmagic Design › Multbridge Extreme AES/EBU, DB25
  • Bob Zelin
    January 24, 2006 at 11:54 pm
    yes – this will work.
    BUT, you can use a cheapo analog audio mixer just for monitoring your audio, and simply send the embedded audio between your Blackmagic and your SDI VTR thru the SDI video cable !
    Bob Zelin
  • Nico Sandhof
    January 25, 2006 at 7:25 am
    “yes – this will work.
    BUT, you can use a cheapo analog audio mixer just for monitoring your audio, and simply send the embedded audio between your Blackmagic and your SDI VTR thru the SDI video cable !”
    thanx.
    We did not attach permanently one SDI-VTR. And the Behringer digital mixer is amazingly cheap. We use that also for the a speaking.
    We do not use that direct analog signal of the Multibridge, because the A-d/d-A transformation takes place after SMPTE (-18dbfs = 0db(r)). Here in Germany we work after EBU and “radio house standard level – Funkhausnormpegel” (-9dbfs = 0db(r) = +6dbu).
    Everything not so simply… 😉
    Greetings,
    Nico
