Activity › Forums › Avid Media Composer › “MTV transitions” in AVID
  • “MTV transitions” in AVID
    Posted by Bill Stewart on May 19, 2010 at 11:38 am
    Hi, I’m rather new to Avid and I’m just wondering if there’s a plugin or an easy way to make MTV-like transitions.. See clip to understand what I’m saying: https://www.youtube.com/watch?v=rV7JzavkLw4
    0:26 Blur, wipe
    0:40 White flash
    2:40 Curtain effect
    I have some idea how to do this in After Effects (except the “curtains”) but is there some way (plugin maybe) for Avid to make the process faster when editing? My main concern is the time it takes to export animations from avid, render them from AE and then import to Avid again. Just for a transition!! Please help.. thanks in advance.
    Grinner Hester replied 16 years, 4 months ago 3 Members · 2 Replies
  • Shane Ross
    May 19, 2010 at 9:34 pm
    The blur and the white flash are both PAINT EFFECTS. You put these on the layer above the cut, cut the filler so that it is 5 frames on either side of the cut, and they apply the paint effect. Man…I think this is something I have to show. Lemme see if I can do a small video tutorial on this.
    Not sure about the curtain.
    Shane
  • Grinner Hester
    May 22, 2010 at 5:37 pm
    I use sapphire blurs for the blur wipes. Sapphire glow and BCC glow for the glows, and I create custom mask transitions with animatte or in After Effects.
    Same applies for shows not on MTV.
