Activity › Forums › Adobe Premiere Pro › MTS Interlacing issues
  • MTS Interlacing issues
    Posted by Ryan Tan on August 14, 2013 at 6:56 am
    Footage:.MTS
    Camera:Canon C100
    Format: 1080/50i
    Edit software: Premiere Pro CS5.5
    Workstation: Mac Pro
    We cant seem to get rid of this interlacing/combing issue when exporting to any formats from PP. The footage imports automatically as progressive, and we created the sequences by draggin a clip to the new sequence button so that the settings would match accordingly. Sometimes in the program monitor, the interlacing artifacts show up, and sometimes they don’t. Even after applying BCC deinterlace filter, the exported file still has those issues. Tried interpreting the footage, change field order in seq settings, but none solves the problem.
    Any help would be greatly appreciated. Thanks.
    Ryan Tan replied 13 years, 1 month ago 2 Members · 2 Replies
  • Ann Bens
    August 14, 2013 at 10:35 am
    If your footage is interlaced, you should set up an interlaced timeline. If Premiere does not interprete the footage correct you can correct that in the Modify/Interprete footage.
    If Premiere does not have a default sequence for the Canon (cant remember) you can make a custom one. Make sure the fields are set to upper.
    Then you can export to progressive.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Ryan Tan
    August 22, 2013 at 10:30 am
    Strangely, i thought i tried this solution and didnt work. Guessed I’ve overlooked on this. Everything looks fine now. Thanks for the advice! Cheers.
