Activity › Forums › Adobe Premiere Pro › MTS files in Premiere Pro
  • MTS files in Premiere Pro
    Posted by Adam Bromley on July 28, 2011 at 6:36 am
    I am using Premiere Pro CS5 to edit native.mts files. When I import the files it says incorrect format. However they do import and I can edit them in Premiere. They are all unrendered however and very slow to work with. Can someone help me out with a good workflow. Of course I could transcode the files but this is time consuming to and I nned to purchase 3rd party software to do that. I am running Premiere Pro on an iMAC. Is it because my system is too slow to deal with these highly compressed files? Does CS 5.5 do a better job.
    Thanks for any help,
    Adam
    Todd Kopriva replied 15 years ago 3 Members · 4 Replies
  • Todd Kopriva
    July 29, 2011 at 12:51 am
    The best way to answer that question is to download the free 30-day trial and see for yourself.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Adam Bromley
    August 5, 2011 at 8:33 am
    Thanks Todd, I didn’t realize the free trial came with all the necessary codecs. CS5 trial didn’t have them.
    Adam
  • Darin Griffith
    September 23, 2011 at 12:44 am
    The CS5.5 trial I downloaded didn’t have all the codecs either. I know because I have the full version of CS5 and it works with MTS files fine. I thought I would give 5.5 a try but it won’t work.
    Why give us a trial version that won’t import any kind of clip that you may be working with? My buddy is using the Design Standard trial and it doesn’t have any kind of handcuffs on it that we’ve seen. Kind of hard to evaluate something if you can’t use it.
  • Todd Kopriva
    September 23, 2011 at 3:35 am
    There is no limitation on the Premiere Pro CS5.5 trial version.
    If the codecs aren’t working for you, that’s a bug. In the rare instances where I’ve seen that occur, it has been fixed by uninstalling and reinstalling.
