Activity › Forums › Adobe Premiere Pro › mt2 files in Premier CS4
  • mt2 files in Premier CS4
    Posted by Brian Scott on September 17, 2011 at 6:39 pm
    I’m having an audio issue with m2t files. If I select the clip and try to use the “Source Channel Mapping” function everything is greyed out. Is this normal? Seems to make it pretty useless. How can you work with the clips if you have to edit all the audio separately?
    Brian Scott
    President
    Image Design Productions, Inc.
    Brian Scott replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
