Activity Forums VEGAS Pro Mpg wont import into Sony Vegas 8.0a properly, if at all.
  • Mpg wont import into Sony Vegas 8.0a properly, if at all.
    Posted by Jack Carver on July 13, 2008 at 7:15 pm
    Mpg files wont import into my registered and activated Sony Vegas 8.0a build 179. Some import without audio but most won’t import at all, giving the error: “Warning, an error occurred while opening one or more files. The file is an unsupported format.” Then it has the file location.
    I should imagine I’m missing a plugin, if that’s the case, could somebody tell me which?
    Thanks in advance.
    Leslie Wand replied 18 years, 1 month ago 5 Members · 10 Replies
  • 10 Replies
  • Allen Zagel
    July 13, 2008 at 11:39 pm
    Hi
    What kind of MPG clips are they? Where are they from?
    Allen
    ASX Media Group, Inc.
    https://www.asxvideo.com
  • Leslie Wand
    July 13, 2008 at 11:56 pm
    try 8b and new mpeg.dll
    leslie
  • Steve Rhoden
    July 14, 2008 at 1:22 am
    You have me at a lost there Leslie,
    What mpeg.dll trial are you speaking of?
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
  • Leslie Wand
    July 14, 2008 at 4:33 am
  • Jack Carver
    July 14, 2008 at 3:44 pm
    They are straight from a Sony Handicam, not sure what type of mpeg though. I believe there’s a way to test which it is?
    I’ll try suggested .dll, thanks.
  • Mike Kujbida
    July 14, 2008 at 3:49 pm
    Is this a miniDVD camcorder?
    If yes, are you using the File – Import – DVD Camcorder Disc feature?
    If this is Vegas Pro 8 you’re using, it’s up to 8.0b so you might want to do the upgrade to see if that helps.
  • Jack Carver
    July 14, 2008 at 3:55 pm
    I’m not sure about the camera specifically, it’s footage that my friend has transfered to me over msn, the files aren’t corrupt because he can edit them fine in Premiere Pro, upgrading isn’t an option I’m afraid.
    Also, the plug-in made no difference to my problem.
  • Allen Zagel
    July 16, 2008 at 12:18 pm
    Here’s a free little program you can download that will tell you exactly what kind of file it is. It’s called G-Spot.
    https://www.headbands.com/gspot/v26x/index.htm
    Scroll down a bit and click on “Super Quick Start for Newbies”. Then you can download it from the link above. It’s an indespensible little piece of software!
    Allen
  • Jack Carver
    July 16, 2008 at 12:56 pm
    Thanks a lot. I ran the program, says it’s MPEG2, it also says the correct codecs are installed.
  • Leslie Wand
    July 16, 2008 at 1:23 pm
    try using mpeg2repair.
    leslie
