Activity Forums Adobe Premiere Pro MPEG2 settings for TV
  • MPEG2 settings for TV
    Posted by Melanie on August 30, 2005 at 2:12 pm
    I am trying to render an MPEG2 file (for broadcast) from Prmeiere Pro v.7.0. But instead of giving me 1 output file (one .mpg) it generates 2 files. Could anyone tell me what I’m doing wrong. My settings look alright. ?!? or maybe not 🙁
    Video Summary:
    Codec: MainConcept MPEG Video
    Video Type: MPEG-2 Video
    Quality: 5.00 (high quality)
    TV Standard: NTSC
    Aspect Ratio: 4:3
    Frame Rate: 29.97 fps drop frame
    Profile: Main Profile
    Level: Main Level
    Program Sequence: Interlaced
    Field Order: Lower
    Bitrate Encoding: VBR
    Encoding Passes: Two
    Target Bitrate (Mbps): 5.6840 (low quality)
    Maximum Bitrate (Mbps): 8.1200 (medium quality)
    Minimum Bitrate (Mbps): 0.1920 (low quality)
    M Frames: 3
    N Frames: 15
    Closed GOP every: 1
    Macroblock Quantization: 10
    VBV Buffer Size (2K bytes): 112
    Noise Control: Noise Sensitivity
    Noise Sensitivity/Reduction: 5
    Write SDE: Do not write
    Force VBV Delay: 0xffff
    Progressive Frame: Interlaced
    Intra DC Precision: 9 Bits
    Audio Summary:
    Codec: MainConcept MPEG Audio
    Audio Format: MPEG-1 Layer II Audio
    Audio Mode: Single Channel (Mono) Mode
    Psych Mode: Psychoacoustic model 2
    Bitrate (kbps): 96
    Sample Rate: 48 kHz
    De-emphasis: No emphasis
    Enable CRC: Off
    Set private bit: Off
    Set copyright bit: Off
    Set original bit: Off
    Multiplexer Summary:
    Multiplexing Type: MPEG-2
    Bitrate Type: Variable
    Packet Size (bytes): 2048
    Packets per Pack: 1
    Sectors Delay (ms): 0
    Video Delay (ms): 180
    Audio Delay (ms): 180
    Video Buffer Size (kB): 224
    Audio Buffer Size (kB): 4
    Mux Rate (kbps): 0
    Max file size (MB): 0
    Pulldown: Auto
    Frame Time stamp: All frames
    Write Program end code: On
    Align Sequence Header: Off
    In advance thanks a lot for any help.
    Melanie
    Melanie replied 21 years ago 2 Members · 2 Replies
  • Mike Velte
    August 31, 2005 at 11:33 am
    Turn ON audio multiplexing in the Adobe Media encoder to Multiplexing for DVD or better yet, choose a Mpeg2 Preset, not a Mpeg2-DVD preset and audio will be muxed with video.
  • Melanie
    August 31, 2005 at 11:55 am
    I got it.
    Thanks for your help!
